Allison/Duramax Badges
Hey, guys i was courious where you could find the badges, i noticed on the header of this website, they have the Allison and duramax all in one badge...is it factory in 06, or is aftermarket or what? thanks for your help....
It's the new badge that is on the latest HD's with the new LBZ Duramax. You can obtain them from your local GM parts department. They look great.
Will they fit in the same holes as the 05 badges?
If you were to take off your current badge, you would notice that there are no holes anywhere. They are the exact same size, if that is what you are wondering. After taking the old ones off, just stick the new badges on.
Oh Ok. I didnt realize the badges were stick-on's. I may have to make that switch. The new badges look awesome. Any tips on getting the old badge off safely?
Some guys have had luck using a hair dryer to heat the adhesive. A little fishing line used carefully might also help you out. Finally, Goo Gone or similar would take the remaining adhesive off and give you a clean surface to start with for the new emblems.
