Adding after-market speakers to stock deck
cnw20
I have a 2003 Sierra EC SLT and am thinking of upgrading the speakers to Alpines, JLs or MBQs without changing the head unit - will it be worth it or must I replace the deck and add an amp to get decent sound? Thanks.
The most bang for your buck would be to install an Infinity Basslink in the back seat. The basslink can be purchased on ebay for less than $200, then add another 20 or 30 bucks for wiring.
But if you go ahead and change the factory speakers, consider this:
a) In the front doors, the factory tweeters are not where the woofers are. Most speaker replacements ignore this, moving the tweeter to be coaxial with the woofer. But this will eliminate your direct line-of-sight sound path to the tweeters, so you'll lose imaging. Better to go with components--or coaxial speakers which you can disassemble--so you can put the new tweeter right where the old GM tweeter was.
b) As delivered, my front door woofers were 4 ohm, but my back door full-range speakers were 8 ohm. So much for GM caring how things sounded.
If you eventually change out the head unit, you'll hear an immediate improvement in the clarity of the sound, regardless of whether you change out the speakers.
nothings wrong with 8 ohm speakers.
You just wont find many replacments to fit it that are 8 ohm
i would just replace the front, the improvment should satisfy you
Even the most two-bit sweatshop of amplifier designers in some hell hole in sri-lanka wouldn't be cought dead designing the rear channels to operate at 8 ohms while the front channels operate at 4 ohms.
Ergo, go ahead and put 4 ohm speakers in back, the GM radio will thank you for correcting the situation.
if the amp is designed for 8 ohm and you put in a 4 ohm load, you chance overheating the amplifier becuase of the higher current draw
The sky is falling. The sky is falling.
85 dB 8-hour period
85 - 90 dB 2-hour period
90 - 100 dB 1 to 2-hour period
100 - 110 between 2 and 15 minutes
110 - 120 less than 30 seconds
130 dB ANY EXPOSURE WILL RESULT IN PERMANENT HEARING LOSS
Oh shiat.
I just went throught the same thing with my '05 Sierra. I bought a Pioneer head unit, Infinity 6-1/2" for the doors, 4"x6" for the rears and the Infinity Basslink. I installed everything except the Basslink because I was in the midst of a Lemon Law dispute with GM. The Basslink would involve the most labor to install and I wanted to wait for the Lemon Law outcome before wasting the time. Basically, a long story short, I won the dispute and had to remove the equipment. I removed the head unit first and drove around a week with the Infinity speakers and the stock head unit. IMO, the speakers are the key to the sound. The stock unit wouldn't push the speakers as loud, but the quality of sound was leaps and bounds above the stock speakers.
The new truck GM is sending has the Bose Premium system. I will be content with the Bose without upgrading...I think. I purchased everything except the Basslink from Crutchfield. They were kind enough to allow me to return the equipment for a refund. I now have a brand new Basslink to get rid of if anyone wants one. Basslinks work very well in space the size of a truck cab.
FYI: i installed mb quart three way components (6.5"woof, 4"mid, 1" tweet) in the front doors of my 01 yukon. (i put the mid in place of the factory tweet in the door, and put the mb tweet in the "a" pillar like 02 models) in addition, i also replaced the rear door speakers with 6.5" mb quart co-axials and the "d" pillar 3"ers with mb quart 3.5" co-axials. HUGE IMPROVEMENT!!! some said it would be a waste without upping the power - i figured i would up the power if the speaker mods didn't do much - i'm stopping here - like i said - huge improvement. go for it.
  • 4 weeks later...
Installed the 4 Infinitys to the stock head unit and boy what a difference! Can still use more bass though. How hard is it to install the BassLink to the stock deck? Thanks again.
    Clark_Elite
    Clark_Elite
  • Who's Online   5 Members, 0 Anonymous, 384 Guests (See full list)
    • Glad I found this post before posting a question. My ‘09 has been throwing those codes and P0442. I replaced the gas cap as it was trashed to begin with and the purge solenoid valve under the hood but still get the code every now and then. Dealership said I need to replace the vent lines as the previous owner use cheap fuel line that feels more like a balloon. They also said the charcoal canister and the “canister vent solenoid/service kit” so it relocates the filter up by the top of the transmission. Vent solenoid is cracked as the previous owner just let it hang loose. Too lazy to put it back on its bracket. If I put it on there the hose kinks and I thinks causes a whistle when I fill up.  Only issue is the parts guys can’t tell me which one I need as it shows two styles. One has a jointed section. Which should I use?  Thanks.  I apologize for hijacking the thread
    • UPDATE 3: Supposedly you need any cluster OTHER THAN a WT model cluster to have full steering wheel functionality. Went back to the part truck and removed the all terrain cluster, trim, and snipped as many wiring harnesses as possible to pull out the factory terminal leads if needed 😂 that poor donor truck…    As of right now I’m relying on Darth_Vader’s thread and YouTube videos. will update.
    • Was commenting on the engine labs article on lifter failure.
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
