Help please!! Annoying Radio Problem
rwthompson67
I bought the truck new 9 months ago. Last month the radio started acting up. The time display on the radio (6 disk in-dash, AM/FM/XM) almost always resets to 12:00 whenever I start the truck. I say "almost" because it is only about 80-90% of the time. I can't figure it out and it's really bugging me. :cool:
Any help would be appreciated.
Thanks
Rick T.
Sounds like a momentary loss of power to the radio. I assume the vehicle starts okay? Not that this is a 100% guarantee that there's not a battery or cable connection problem. I've seen some pretty bizarre behavior with a battery cable that wasn't quite tight enough. They may start okay, but weird electronics problems.
That'd be my first step. Next would be to monitor battery power right at the radio when this occurs with a Fluke (or other meter) in its min/max mode to see if there was any power dropout.
Or maybe from the Techlink 04/2005
This information applies to 2005 Buick Rainier, 2005 Cadillac Escalade, Escalade ESV, Escalade EXT, 2005 Chevrolet Avalanche, Express, Silverado, Suburban, Tahoe, TrailBlazer, TrailBlazer EXT, 2005 GMC Envoy, Envoy XL, Envoy XUV, Savana, Sierra, Yukon, Yukon XL, Denali, 2005 HUMMER H2 with CD Player Radio (RPOs UB0 or UB1).
Some customers may comment about one of the following conditions:
- Long CD load-to-play time
- CD ejects with an error message of CHECK CD
- CD does not return to previous track after an ignition cycle
- The clock resets to 12:00.
- CD stuck in player, CD won’t play, or won’t eject without any indication of clicking noises and/or mechanical operation.
DO NOT replace the radio for these conditions.
A software anomaly within the radio has been found. Reprogram the radio with an updated software calibration. This new service calibration was released with TIS satellite data update version 2.0 available February 7, 2005.
TIP: A unique labor operation number R0125 covers this Radio -- Reprogram (0.4 hr.). This number will not be published in the Labor Time Guide.
TIP: Be sure your Tech 2 is updated with the latest software version.
TIP: Advise the customer that home-burned CDs must be burned with a "closed session" or the formatting will be incomplete and the player will not read the CD. CDs should not have adhesive paper labels affixed to them, because the labels may lift off in the player.
- Thanks to Doug Daugherty
:banghead:
I bought the truck new 9 months ago.  Last month the radio started acting up.  The time display on the radio (6 disk in-dash, AM/FM/XM) almost always resets to 12:00 whenever I start the truck.  I say "almost" because it is only about 80-90% of the time.  I can't figure it out and it's really bugging me.  :banghead:
Thanks
Rick T.
Wife`s `02 Trailblazer did the same thing!!!!!!!! Pissed her off, cause the radio would POP!. Dealer CND it. Traded it in, as i was removing the K&N filter, I noticed the battery acid down the inside fender. HA ! Battery leaked. Go figure, an ACDelco positive terminal!!!!!!!!!!!! Who would have thunk that????????!!!!!!!!!!!!!
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
    • Sounds like maybe it's announcing Navigation turns or Alerts (it mutes the music) ? When it mutes again, turn up the volume quickly and see if maybe the navigation volume is really low?
