Sirius Installed w/ KNGM1
Just installed a Kenwood SR902, antenna, and KNGM1. When I press my "band" button, I get SIRIUS1 on the display, but it only shows for a second and then disappears... same with SIRIUS2.... I can hit a few buttons, and I will get it to display "1", but nothing else. what can it be?
Well, it may be in your menu, that your default display is on. Try changing the display. Any sound heard? Sirius should default to channel 184. Then, you need to call them with the serial number of hte unit, and your VIN. Oh, you need to pay them also. They may have online activation by now, never checked. If you`ve done all that, then like I said, there is a setting not right.
The service was paid for and activated. There are no settings that I am aware of.. simply go to the SIRIUS1 or 2 band, and go throught channels. No, I did not have factory XM either... Seems like the only channel I get is "1". I just went out and grounded the KNGM1 to the body, it was grounded to the cig lighter before.. Still no go. Thoughts?
Is the one channel you get actually sirius 1? If so it would be "hits" and playing current pop music. I'm curious if they activated it correctly. The night i activated mine, they had to do it twice for some reason.
Hmm... I think it is actually Sirius 1.. I was actually able to preset it on a few buttons, and it retains it even after I shut the truck off and back on.. So I am pretty certain power and ground are not the issue. I get no music though.. If I raise th volume, I get hiss and very slight static sound. Just not sure who to call first.. Soundgate or Sirius. ?
I thought, but I could be wrong, that you had to use the SR903 box from Kenwood with the Soundgate interface and the DEI box would not interface properly.
Jason
  • 3 weeks later...
Here's an update: I called Soundgate for assistance, and Captain Obvious said, "you have a faulty kngm1 or tuner". Well.. Now they are both changed (KNGM1v7 & SR902), and Sirius was called to activate the new tuner. Installed them and now when it first fires up, It reads "antenna". If I try to move through channels, it does nothing... Just sits in channel "1". No audio. The antenna is in a good spot, and connected. I drove down the street and back, but nothing. WTH?!? :)
WOW! You may be better off with an aftermarket head unit? Food for thought! You`ve got a screwed up mess there. Wish you were close, I `d come over and look.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
