AC Always On?
Fitty
I've got an '01 Silverado, standard cab, Z-71. The heat and AC seem to work fine EXCEPT, the AC seems to never really shut off. If I turn it off it still blows in chilled air (no, it's not the chilled duct-work -- it stays cold for as long as I'm driving). I can over-ride it with heat, but that's not the way it's supposed to be (is it?).
Fitty :banghead:
No, the A/C does not stay on when you turn it off. It does come on automatically when you put it in defrost though.
If you turn it off, go out and look at the compressor clutch and see if it's turning. I'm not talking about the pulley that the belt is on, because that's always turning. Look at the plate on the front of that pulley. If it's stationary, the compressor is not on.
Then why does it continue to blow chilled air for as long as I drive it? If I stop, restart later, it still blows chilled air. I know the difference between chilled ait and outside air. :banghead:
I have no idea. You're there and I'm not. I'm not debating what you're saying. I can only tell you that the a/c is not SUPPOSED to be on all the time. I'm not saying yours isn't. If you don't even want to take the first step to find out what's going on, I can't help you.
Hey GM-Tech, why are you being so touchy? I just asked a question. Why do you assume I hadn't already checked the compressor clutch?. Trust me, I know HOW an AC system works. What I don't know is why the AC is always working even when the AC switch and indicator light is "off". Bad switch? Wiring problem? Never happened before to a Chevy truck? I just wanted some advice before I take it to the dealership. Sorry.
Fitty :confused:
"If you don't even want to take the first step to find out what's going on, I can't help you."
I guess I'm touchy because you postings, including this one, come across with a somewhat snotty attitude. How the heck am I supposed to know what you checked and what your level of expertise is? Some people that ask questions here can barely change their own oil.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
