GM SiriusConnect
edb007
The GM SiriusConnect was scheduled for release in November 2005 (at least that is what a Sirius web site states: http://www.orbitcast.com/archives/sirius-h...iusconnect.html.
Has anybody installed one, found one, or even saw one.
I have called a couple of Sirius distributers and most act like they have not heard of it. A few say it was delayed by GM and will not be available until March. I do not believe GM has any involvement with the product or its release. Any information appreciated.
  • 3 weeks later...
I don't have any specific information but it I have been watching for its release. The following website http://www.thesiriusstore.com/product_info...rius-car-tuners has been showing that the release date keeps getting bumped out.
However, I did notice the picture of the unit has changed to show specific wiring harnesses and now it appears there is no normal sirius antenna, so maybe it will use the existing xm antenna, which would be great.
  • 3 weeks later...
Guest chevydeerhunter
Soundgate already makes an adapter that will allow Sirius on XM ready factory radios for 03 and up. You have to use the Sirius tuner made for Kenwood.
SIRKEN1
KNGM1
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
