BG46 Posted January 2, 2006 Posted January 2, 2006 Just returned from trip and the cruise on my Yukon XL quit working. Everything was OK for about 1/2 of the trip. Stopped for gas and a beverage, got back on the freeway and the cruise won't turn on. I checked and replaced the cruise fuse but it still isn't working. Didn't realize just how much I use cruise until it doesn't work. 18 hours on the interstates with light traffic and no cruise just wasn't comfortable. Any ideas on what happened to the cruise????
redvett Posted January 2, 2006 Posted January 2, 2006 Just returned from trip and the cruise on my Yukon XL quit working. Everything was OK for about 1/2 of the trip. Stopped for gas and a beverage, got back on the freeway and the cruise won't turn on. I checked and replaced the cruise fuse but it still isn't working. Didn't realize just how much I use cruise until it doesn't work. 18 hours on the interstates with light traffic and no cruise just wasn't comfortable. Any ideas on what happened to the cruise???? <{POST_SNAPBACK}> Did you try taking your foot and pulling up on the brake pedal while driving & engaging cruise. If it works the cruise/brake switch is out of adjustment.
BG46 Posted January 4, 2006 Author Posted January 4, 2006 Just returned from trip and the cruise on my Yukon XL quit working. Everything was OK for about 1/2 of the trip. Stopped for gas and a beverage, got back on the freeway and the cruise won't turn on. I checked and replaced the cruise fuse but it still isn't working. Didn't realize just how much I use cruise until it doesn't work. 18 hours on the interstates with light traffic and no cruise just wasn't comfortable. Any ideas on what happened to the cruise???? <{POST_SNAPBACK}> Did you try taking your foot and pulling up on the brake pedal while driving & engaging cruise. If it works the cruise/brake switch is out of adjustment. <{POST_SNAPBACK}>
BG46 Posted January 4, 2006 Author Posted January 4, 2006 QUOTE(BG46 @ Jan 2 2006, 02:05 I'll definately try it. Are there any plug in's I should check or connections of anykind? PM) Just returned from trip and the cruise on my Yukon XL quit working. Everything was OK for about 1/2 of the trip. Stopped for gas and a beverage, got back on the freeway and the cruise won't turn on. I checked and replaced the cruise fuse but it still isn't working. Didn't realize just how much I use cruise until it doesn't work. 18 hours on the interstates with light traffic and no cruise just wasn't comfortable. Any ideas on what happened to the cruise???? <{POST_SNAPBACK}> Did you try taking your foot and pulling up on the brake pedal while driving & engaging cruise. If it works the cruise/brake switch is out of adjustment. <{POST_SNAPBACK}> <{POST_SNAPBACK}>
pm26 Posted January 7, 2006 Posted January 7, 2006 Your cruise conrol actuator could have taken a dump.
