Fuel Tank Problem
LastBattle
:cheers:
I have a 1987 Sierra Half-Ton 4x4. Both tanks have fuel. The fuel switch on the dash has power to both sides and works. The engine only runs on the "left" side. When I switch to the "right" tank, it does not switch and the fuel contines to come from the "left" tank.
The fuel gauge does not change when I switch between the two. Even when one has less fuel, it does not read right side.
Suggestions Please...
Thank you,
Bob
Wow, I had a hard time figuring those systems out even when they were currently in use. Shematics and information was always slim. I couldn't even guess at this point.
:cheers:
Thank you,
Bob
I thought those trucks used an electrical valve to swap between the tanks. Have you troubleshot power to the valve?
