Flowmaster exhause on 2500HD w/8.1L
I want to put flowmasters on my 8.1L HD. However, I want to keep the factory pipes and only cut out the factory muffler. Flowmaster doesnt make a 4 inch inlet/outlet. Will it be ok to neck it down to the flowmaster? Will it be too restrictive with a 2.5 inch neckdown to the muffler then back up to the 4 inch factory on the way out?
Or will I just be better off getting a Magnaflow exhaust?
It's 3" dual's and everybody makes those. You're better off with a Magnaflow muffler, Flowmaster is to loud. If you do use Flowmaster get some of the "special order" BIG Block 80 series or the drone will drive you or everybody around you nuts, maybe both. Hook up to the 3" pipes with two mufflers or a dual in dual out like mine and run two 3" tail pipes. There's no need to replace the pipes to the muffler.
Vernon
SimplyRad i love that camera shot, how did you mount the camera
I mounted the camera on the step bar with a universal camera mount.
Thanks, I was looking for a different viewpoint for an exhaust video. My rev limiter is still set and I couldn't get the real sound just sittin' there.
I have an '04 2500HD with 8.1L and Allison. I have Flowmaster 70/80 (cant remember) with the dual in / dual out muffler. IT SOUNDS AWESOME and is not too loud. Very quality sounding. Rumbles a little and is onlt luoder when floored. I have net heard a truck with Magnaflow - I DO KNOW FLOWMASTER SOUNDS SWEEEEET !!
:cheers:
  • 3 weeks later...
Here is what I did, and it worked perfectly. Went with the 50 Series big block Flowmaster. Its fairly long, to handle the huge volume of exhaust flow. It comes in 2 configs, and both calculate to almost the same outlet area. I went with the 2-2.5" outlets. The other is1-3.5" outlet. If you measure your factory pipe on an 06, it has 2-3" outlets combined into 1-4"outlet. I turned down mine and skipped the tail pipe. You end up with 2-2.5"ers instead of 2-3"ers basically. With the far less restriction throughout the 50 series vs. stock, this muffler provides the proper back pressure for torque, like the stock one does with the great sound that the stock one doesnt have. I looked long and hard, and this was the right choice for me. I have a 40 series on my 5.3 liter, which is the loudest street muffler they make, and this 50 sounds very similar coming from a bigger displacement. Love it.
dont know, maybe its just me...but i have always been a fan of the stock exhaust on the HD's. I think they sound pretty tough just like they are, just my opinion though as i have never been a big fan of a "LOUD" truck.
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
