8.1 engine missing and stinks.....
kevinmach1
I have an intermittent problem with my 02 yukon with the 8.1. I had a miss that we changed the plugs and plug wires out with new ac delco parts. It runs great most of the time, but once in a while I get a wierd rough idle, sputtering and low power symptom with the exhaust smelling really nasty. If I shut off the engine and restart, the problem goes away for a few days.
Any ideas? I am questioning if I have a bad coil?
Thanks..Kevin
Any codes set?
If the exhaust is smelling nasty then your running rich or the engine is missing. That should set a code.
DEWFPO
