Pioneer DEH-P4800MP & PAC SWI-PS
Bought these from Crutchfield and finally got around to installing them yesterday. Very nice. The sound is much nicer than the stock deck was, and the SWI-PS works seamlessly with the steering wheel controls. I still have to run my pre-amp outs back to my sub, but so far I like it. One nice thing about Crutchfield is that they send you everything you need to do the install. Wiring harness, antenna extension, mounting kit for the head unit and very detailed instructions. I bought the optional Metra VT-GMRC-01 GM Class II Data bus Interface to retain the chimes. I even still have power for the radio after you remove the key, just like stock and now I have an amp turn on as well.
How tough was the steering wheel module to install? Did Crutchfield include the instructions for that as well?
The instructions came with the PAC unit. It was simple to install, at least with the radio I got. There is a 1/8 plug in the back of the head unit that you can use for a wired remote that the PAC unit plugs in (the head unit comes with a wireless remote). You connect a hot, a ground and one wire to the harness coming from the steering wheel and it takes about 5 minutes to program. Pretty simple.
Hi,
I bought the same head unit, not for my truck but for my car. I don't have steering wheel controls in my car. I assume the SWI-PS is for your wheel controls?
Anyway, I selected the Pioneer 4800 because they support adding a direct iPod interface very easily and plus the 4800 will support the new BlueTooth adapter that Pioneer is releasing this month or next. So you plug in two module (adapters) and bang, you have iPod and Blue Tooth cell phone support. This should be pretty nice. I haven't installed the 4800 yet. Looking to do that Wednesday night.
Are you feeding the 4800 to an amp? What make/model?
Did you get after market speakers also? Make/model?
Thanks,
TNT
Hi,
Thanks,
TNT
Yes, the SWI-PS is for using the stock steering wheel controls. The rest of my gear is in my sig.
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
