integrate Aftermarket DVD to TNR via RSE
i have installed a TNR (non-lux) in my '03 Tahoe with a PAC-Audio AAI-GM24. I just had a Rosen G10 installed and hooked into the 2nd aux port of the AAI-GM24. can this be hard-wired into the ClassII databus instead so that I can use the built-in RSE mute funtions and not have to listen to Thomas the Train in the front speakers. My son is not old enough for the headphones yet.
thanks
Not to say that it's completely impossible to do what you're looking to do...but it would be very difficult to pull off, since IIRC the RSE is strictly for the factory DVD. If your truck didn't originally come with the factory DVD, all you can hope for is that the RSE wiring is still in place...and then, figure out which one is the RSE audio wire and tap the audio of your Rosen into that. I'm just guessing at all of this, but I would think what I suggested does make some sense...at least in theory.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
