In-Dash Computers
Ok - I saw a great in-dash computer screen awhile ago. Cant remember where. This one was positioned down on the center console where the power outlets are located. The person had cut out that entire section and put in a monitor. Any instructions or info on how to do that would be great! This is a project that I would like to have done later this summer. So I need to find the info now to get moving on it.
check out www.mp3car.com
they have everything you need to get started. Try searching SILVERADO and you will find some interesting projects there.
I have been working on getting one for a while but it is on hold right now due to limited funds cause I am trying to get a boat.
Here it is guys... I finally found the lost link.
http://reviews.cnet.com/4520-11198_7-6396851-1.html?tag=nav
Step by step instructions of putting a computer in your truck.
I will get some pics up shortly. Just got a new camara from BB.
PS, how are you going to mount your screen? I know you have the almost double din dash cause you have a 2005. I am going to move my ac controls down and replace the entire front with an 8 inch. I am currently waiting on a guy to make a mount for me so who knows.
I've thought of doing something like this before, but how well do they hold up in extreme temperatures? It's not uncommon for it to get to -30 here at my house, and we often visit my in-laws, where it's not uncommon to get above 120 (And who knows what the inside temp gets to when the car is parked there!).
I'd hate to invest my time & money into something like this, only to have it melt or freeze to death. I've seen the interesting things that the heat has done to my cell phone & ipod screen if I accidentally leave them in the car on occasion, what would every day in the car do to the stuff?
most likely not a good idea for you. The touchscreen def. would NOT work in those extreme conditions. even below freezing the touchscreen begins to malfunction until it warms up.
Im not saying the touchscreen would break but in those freezing conditions it would take forever for it to warm up and start working.
don't know much about hot temps. might be ok? anyone else know?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
