Stupid starting issue
2001-Z71
It started many months ago. The Flex Fuel sensor threw a code and was replaced. Before this the truck began to need a few extra cranks of the ignition in order to start. The fuel pressure reg. was replaced and finally the fuel pump. The problem still exists and appears to be getting worse. It has never failed to start but does need approx. 3-5 seconds of cranking to get it to start most of the time...but when it does start it does not seem very convincing...I know that sounds stupid but the start appears very forced. Could it be a crank sensor going out?
Thanks,
Sean
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
