1990 Chevy K2500 4X4 For Sale
Up for sale is my 1990 Chevrolet Scottsdale 2500 4X4. This truck is in amazing shape for a 1990. My father is the original owner, he drove it till 02 and then I drove it till last week. Its got a fuel injected 350 in it with a K&N Fuel Injection Performance Kit, a brand new Y pipe, high flow catalytic converter, and Gibson dual stainless exhaust that exits tight around the Reese hitch. It is light french blue metallic and white as you can see by the pictures. I put Bushwacker fender flares on in 03 which really accented it. The rear right fender flare has a slight crack on it that is hardly noticable. I just recently put a 4" cowl induction functioning hood on along with a billet grille insert. The windows are all tinted 20 percent, black to chrome on sides and chrome titanium metal tint on the rear sliding window. The interior is in very good shape. I just fixed the headliner so that is in perfect shape. The seat has a small rip on the drivers side but other than that its perfect. I have a really nice Pioneer cd player inside with an XM Roady hardwired in to the Pioneer. I have a 1400 watt amp behind the seat with two 10" subwoofers..the stereo sounds amazing! It has 2003 Silverado Rims on it with Firestone tires that have about 60% tread left on them. The corner lights, parking lights, and taillights are all aftermarket clears. The eight foot bed has a bed line, bed mat, and Extang Platinum tonneau cover on it. The plow is an 7'6" Meyer poly plow. The best part is the truck only has 56,500 miles on it! I still have the original window sticker for it along with a clean title and all manuals. It also has fiberglass running boards.Along with the truck goes the original lights, original rims, and two extra ( the truck has a set) 55 watt KC highlights $4800 OBO I do not know how to post a picture here so check my personal photo for a picture of the truck by clicking on the word "03Silvy" Thanks.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
    • I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.   One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
