Tire pressure
The sticker in the door recommends 50psi  Thats the max pressure of the steeltex firecraps so I gave it a try and it rode rougher than ####.
Is it just me or is it odd to have the recommended pressure be the tire max pressure?
Try 40 psi, you should notice a difference there.
The door sticker is just a guide, different tires have different specs, just keep that in mind.
01 his truck has the steeltex tires.  I had the ATs and it said 35 also i ran em at that till i dumped them.
Id try 40-45 and see how that is
I run 50 in my 245's Steeltexs, it came with 40 and I put 50 and couldnt tell any difference. I like the steeltex's actually, had them on another truck and they were a great tire. I actually want to jump up to the 265 steeltex's but they only come in 10 ply!
Thats the good news, the 10 ply are very solid tires.
Are there any dis-advantages to a 10 ply, like less grip in snow or anything??? I really like the Steeltex design and it matches my truck good, but they just need to be a little bigger, dont think I could squeeze 285s in there?
Tire pressure on the door is what should be in the tires if you are running loaded.  I prefer the higher tire pressures because of less rolling resistance.  Also I do carry a load once in a while.
I have a compressor in the truck so I can air up when I load it. 50 psi is a rough ride but it does bump the mileage a bit?  Decisions decisions.
