Window Crank Removal
I'm trying to remove the door panel on my 2003 Silverado. How do I remove the Window crank so I can get the panel off?
Grab a rag, stuff it in sideways so it fits behind the handle in between the door. You'll want to slide it in there so the rag gets snagged on the little clip that holds the handle on. Once it's snagged, rotate the rag so it pulls the pin out. Hope this helps.
