Private Purchase Offer???
I got an offer in the mail for $1500 off a full size gmc/chevy. does anyone know if this can be combined with other incentives?
According to the back of the one I received it is eligible for Tahoes,Suburbans, and Silverados etc. It also says that it can be combined with most other national and regional consumer offers for Tahoe, Suburban, and Avalanche. The interesting thing is that it does not mention Silverado or Sierra there.
What do you currently have now? Lets keep in mind that the registration and licence and title fees will equal right aroung $1000-1500 so.... If you have a reliable vehicle right now, I'd hang onto it!
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
