French.........vs.........Irish
Jacques Chirac, The French Prime Minister, was sitting in his office
wondering what kind of mischief he could perpetrate against the United
States when his telephone rang.
"Hallo, Mr. Chirac!", a heavily accented voice said. "This is Paddy down
at the Harp Pub in County Sligo, Ireland. I am ringing to inform you
that we are officially declaring war on you!"
"Well, Paddy," Chirac replied, "This is indeed important news! How big
is your army?"
"Right now," said Paddy, after a moment's calculation, "there is myself,
me cousin Sean, me next door neighbor Seamus, and the entire dart team
from the pub. That makes eight!"
Chirac paused. "I must tell you, Paddy, that I have one hundred thousand
men in my army waiting to move on my command."
"Begorra!" said Paddy. "I'll have to ring you back!"
Sure enough, the next day, Paddy called again. "Mr. Chirac, the war is
still on. We have managed to get us some infantry equipment!"
"And what equipment would that be, Paddy?" Chirac asked. "Well, we have
two combines, a bulldozer, and Murphy's farm tractor."
Chirac sighed, amused. "I must tell you, Paddy, that I have 6,000 tanks
and 5,000 armored personnel carriers. Also, I've increased my army to
one hundred fifty-thousand since we last spoke."
"Saints preserve us!" said Paddy. "I'll have to get back to you."
Sure enough, Paddy rang again the next day. "Mr. Chirac, the war is
still on!" We have managed to get ourselves airborne! We've modified Jackie
McLaughlin's ultra-light with a couple of shotguns in the cockpit, and
four boys from the Shamrock Pub have joined us as well!"
Chirac was silent for a minute and then cleared his throat. "I must tell
you, Paddy, that I have 100 bombers and 200 fighter planes. My military
complex is surrounded by laser-guided, surface-to-air missile sites. And
since we last spoke, I've increased my army to two hundred thousand!"
"Glory be!", said Paddy, "I'll have to ring you back."
Sure enough, Paddy called again the next day. "Top o' the mornin', Mr.
Chirac! I am sorry to tell you that we have had to call off the war."
"I'm sorry to hear that," said Chirac. "Why the sudden change of heart?"
"Well," said Paddy, "we've all had a long chat over a bunch of pints,
and decided there's no foo-kin way we can feed two hundred thousand
prisoners!"
Jaque and Pierre are ditch diggers and work under the direct supervision of Fergus O'rielly. After years toiling in the ditch with minor input from O'Rielly, Pierre asked Jaque why it was that O'Rielly was the foreman and they were the laborers. After much deliberation and no real answer Jaque decided to ask O'Rielly himself for the answer.
Jaque: Hey O"Rielly, Whay is it that Pierre and me, we dig ditches and you just supervise?????
Orielly: Jaque come over here. Let me see you shovel. (O'Riellt proceeds to hold shovel in front of large elm tree) Now Jaque hit this shovel.
Jaque winds up, takes a big swing. O'Rielly moves the shovel and POW Jaque hits the tree.
O'Rielly: Now Jaque do you understand?
Jaque: (Holding very throbbing hand) Oui, Oui, I see. And Jaque returns to the ditch.
Upon returning to the ditch, Pierre says, " Jaque what O'Rielly say?"
Jaque now holds shovel in front of his face and says, "Pierre, hit this shovel"................
  • 3 months later...
