Misrepresentation from GMC employee
nit78
Hello Everyone,
I really need your advise on the following issue!
I just recently bought a 2004 GMC ENVOY from a private person in Texas. The Vehicle had a Salvage title, but before I purchased the truck I called GMC to see if there was any warranty remaining on the truck. The representative I called ensured me that my truck was covered until the end of September 2006.
Based on this information I decided to purchase the truck. Anyways to make the story short, while driving my transmission cooler line blew and the radio stopped working and when I took the truck into GMC I was notified that the warranty was blocked and GMC will not cover it.
I have called customer service and they verfied that the agent made a mistake and the warranty was locked and even though it was their agents fault they will not help me in any way.
Does anyone have suggestions on what steps I can take to resolve this issue and maybe a number that I can to esscalte this issue.
I don't know the answer but I feel if he told you it would be covered then they should cover it. Thats horses**t!
I know and to top it off the a$$ at GMC Customer Centre will not give me any contact infromation or numbers of where I can escalate this issue. That's why I was hoping someone here will be able to help me.
They're not going to give you numbers because they're not liable for the truck. It's been totaled.
I hate to tell you man, but you're going to do a lot of yelling, screaming, running in circles pulling your hair out, and talking to peoples bosses...But in the end, you're probably going to be SOL.
Aftermarket warranty companies probably won't even touch a salvage title. Some insurance companies won't even insure them.
Sorry man...This sucks :crazy:
I don't know why the rep. told you what he told you,as far as the truck being covered,but like Wingnut said your SOL.
I've worked in a GM dealer for almost 17 years and the only thing GM will cover on a "salvage" vehicle is recalls,because recalls are saftey issues and mandated and required by the government (But I've even heard of some dealers giving guys a hard time about doing recalls on "salvage" vehicles) other than that nothing is or will be covered.
On the tranny cooler line they can say that whoever put the truck back together did not tighten or properly install the line,on the radio issue they can say that it was caused by a cut wire that "shorted-out".
We had a Cavy that was an R-Title and they would not cover it which I don't blame them but when a Rep says they will then they should honor what he said. He is their Rep.
Normally I don't blame them for not warranting the truck, but there agent said it was, they should stand behind it. That is what any other buisness would do. I think if it was bad enough a court case/jury would agree that the company should stand behind what they say. Was that call "recorded or monitored"? so that you can prove they said it was covered. Did you tell them it was a salvaged title? If so I would scream and yell, kick and fight, pinch and bite, cuss and holler, tooth and nail. A good lawyer wouldn't hurt either.
That's a very good point. A coworker of mine called our Health Insurance to see if a certain procedure was covered and they told him yes, after he has it he gets a bill saying he wasn't covered for that. Luckily he wrote down the date, time and who he spoke with and they ended up paying because the call was recorded and the Rep told him he was covered.
Should still be covered even with a salvage title, my mom bought an 01 XJ Cherokee in 02 with 11k on it and it was covered until the factory warranty was out. Before my Silverado (also a salvage title) I had an 03 Toyota Tacoma TRD (bought with 4,800 miles in 03 and a salvage title) and all 10 times I went to the dealer with problems they were covered by the factory warranty. That GMC dealer is giving you a load of BS.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle.    What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
