Dexron T-IV or VI? For 4L80/85e?
I read here about Dexron VI (6), but when I went to the GMC dealer, a mechanic said he just came from a class where it was taught that T-IV is the approved replacement fluid for 4L80e transmissions where Dexron III was formerly specified.
I've seen the T-IV bottle, GM part #88900925.
I've never seen a Dexron VI bottle, but I read about them on the forums.
Are people transposing the Roman numerals accidently?
Are there actually two new Dexron specifications?
If so, are both the IV and the VI approved to replace III?
Or am I just hopelessly confused?
Please help...
They are transposing the Roman numerals.
The T-IV tranny fluid (Part#88900925) is for the Aveo's automatic transmission.
(And at this time its used only in the Aveo's,Dexron III is not to be intermixed with the T-IV tranny fluid)
The Dexron VI tranny fluid (Part#88861003) is the replacement for Dexron III.
You can use Dexron VI in place of Dexron III,But you cannot use Dexron III in place of Dexron VI.
GM is currently in the process of depleting all of its stock of Dexron III.
No,Only the Dexron VI replaces Dexron III.
The IV tranny fluid is not to be intermixed with any Dexron fluid.
Unbelievable.
THIS is exactly why I walked OUT of my GMC's service/parts department and came HERE first.
Do you guys realize that the service writer walked back into the parts department and brought out a 12-pack case of T-IV, at $12.93 cents a bottle, (but as a special "favor" for me, he'd knock that down to just $9.70 per bottle, for a total of $112.00 + tax just for the fluid alone), and proceeded to sell this to me for my 2005 YukonXL with only 13,000 miles?.
A little voice inside my head said wait a minute, let me just verify this online first.
I superfically thanked the guy, and escaped with my money in hand.
Now I'm REALLY thanking YOU guys, for setting the record straight.
The people at dealerships cannot be trusted. The mechanic and I were discussing Dexron VI, and the service writer must have transposed that to mean IV.
Unfortunately, it's the service writer's that the customers like me are forced to deal with if we walk into a dealer.
I think I'll avoid the dealer from now on. I'm glad I didn't buy the GM extended warranty. I think I'll put that money toward my own Tech 2 scanner instead.
Can't trust anybody, no matter how many pins and badges they have on.
Thanks again guys, and thanks for the Dexron VI part number.
Do you suppose I can order a case through GMPartsDirect? Or where is the best (non dealer) source for this fluid?
Well don't be too hard on the dealer,because I work at one and I hope you trust me! :driving:
There are soooo many different types of fluids out there its hard for anyone to keep up with them,I had to do a little digging myself on the "T-IV" fluid to find out the information I found for you.
One other thing,the Dexron VI is also available in gallons,Its part# is 88861045.
Unbelievable...I think I'll avoid the dealer from now on.  I'm glad I didn't buy the GM extended warranty.  I think I'll put that money toward my own Tech 2 scanner instead...
A warranty is just a recipe for frustration.
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
