Licence plate lamps
While washing the truck the other day I noticed one of the licence plate lamps was loose. I then found out the entire thing is plastic. Cheap a$$ plastic on top of that. They are held in place by tiny nubs. Mine must have disintegrated so now I got duct tape holding it in. Cant wait to see what they charge for a new one. Worth about 50 cents, probably charge 30 bucks!! Solid as a rock... yea right. :seeya:
Luckily mine are chrome but they have since cheapened those little boogers up more so that now they are a lovely shade of textured black plastic... I wonder if you can still get chrome ones, I've been worried about one of mine breaking and being stuck with black instead of chrome.
Mine are chrome also. I was always under the impression they were metal. No, just cheap chrome PAINTED plastic. You figure at least they would use a better retaing clip, but all they are is little nubs.
Do what I did, Palce a nice neat bead of clear silicone around the base of the "cheap a$$ plastic light" and than put it back in place. Been about 4 months since and still holding fine.
I got rid of my chrome ones (sitting in a box somewhere???) and replaced them with the black ones. Look much better in my opinion. Cost was like $4 or 5 for 2
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
