700cc Posted June 29, 2006 Posted June 29, 2006 I'm trying to quickly decide between a 1500 and a 2500HD. If I get the 1500, I am looking at a 2006 Silverado 1500 EC Z-71. Problem is, this one was invoiced early in the model year, and has an engine/gear ratio I've never heard of. 310 hp "light duty power package" with a 3.42 rear end. I thought they were all 295 hp with either a 3.73 or 4.10 rear end. What gives?
ken1mod Posted June 29, 2006 Posted June 29, 2006 I would recommend against the 3.42 axle ratio. Mine has the 3.73 and I consider it barely adequate. I wish mine had the 4.10s and I run unloaded. Ken
MS3DALE Posted June 29, 2006 Posted June 29, 2006 The 310 hp engine is the "L33" aluminum-block "H.O." 5300 V8 that first became available in '05,It is only available in the 1/2-ton Ext.cab short-bed trucks. 3.42 is now the common gear ratio on 4x4 trucks (This started in '05) with 4.10's being optional,GM restricts the 3.73 ratio to the hybrid trucks and fleet sales until they make so many with 3.42's (Because 3.42 ratio gets better gas mileage this helps GM meet CAFE standards) then they lift the restriction.
pm26 Posted June 30, 2006 Posted June 30, 2006 GM also uses 3.23 ratio axle gears on 2WD trucks, including those with factory tow package. Do 2WD supercabs come with the aluminum H.O. 5.3 as well? With the lame 3.23 axle ratio?
ZZebes Posted June 30, 2006 Posted June 30, 2006 You want to talk about an inadequate gear... My truck has 3.23 from the factory and i HATE them, i want to get rid of them but cant afford the almost 2,000 the dealership wants to swap them for 3.73's i am considering having an outside shop switch them to 4.11
pm26 Posted June 30, 2006 Posted June 30, 2006 Considering 0%/72? How about 0%/0? That's called paying cash for your truck.
700cc Posted June 30, 2006 Author Posted June 30, 2006 Considering 0%/72? How about 0%/0? That's called paying cash for your truck. <{POST_SNAPBACK}> To most of you for your replies, thanks so much. For pm26, thanks for your insightful bs. If I can use someone else's money for 72 months for free (and invest my own in interest-bearing accounts), why would I part with my money now. Thanks again.
MustGoFaster Posted June 30, 2006 Posted June 30, 2006 looks like GM may have changed the production options for 06. picked up a sierra ECSB 4X4 with the L33 and 3.42's loved the way it ran, strong as hell. (but then again I'm trading from a 4.8 w 3.73's)
