2007/2006 2500HD Dmax questions
im going to be selling my burb maybe, and im looking at the 2500hd and the 2500 dodge. But for the 2500hd with teh dmax and 6 speed etc, what are you guys paying msrp/otd/discounts. I know chevy had the whole discounted thingies last year but do they still hand out discounts left and right?... ive been away on the gm scene because i picked up a little subaru wrx sti. Also do you guys have any problems with the 6 speed allison, or is it the best chevy you've ever owned? 650 lb-ft sounds pretty sweeeet. :rant:
2-weeks into my new 06 Duramax 2500HD
Picked up a $50k list truck discounted to $45 then pulled down to $42 with $1500 in trade-in allowance and $1500 in "rebates".
This was here in So. Cal. - dealers still hungry to move product.
Sweet truck. Drives much better than my 01 2500HD 8.1L/Allison
Hearing nothing but good things about the 6 speed Ally and the new DMax. Get one now before the new regulations go into effect in a year or so. Also the Ally in 06' got a new double capacity tranny cooler. This is helping to really keep the Ally cool during stop and go traffic. As soon as someone has the retro kit to put one on the pre 2006 models, its going on my truck.
I bought a 2006+ Duramax/Allison Crew Cab/Short Box LT-3 in February. While most fuys were watching the Super Bowl, I was arguing and getting dirty with the salesman.
This is BY FAR the finest truck on the planet.
And it is likely to stay so, with the Federal Diesel Emmision standards coming online January 1, 2007.
The LBZ engine is unbelieveably powerful and just purrs, no matter what the load. And the six-speed Allison 1000? Hmmm, might be the best part of the deal.
GM is going to have to go very far indeed to better the 2006+ D/A. The 2007 will be called "The Classic" and it will be identical to the 2006+ and it will be replaced by the new body-style and new emmision LMM engine in early-2008.
Get the D/A now, my friend. The deals are great and the rig is the best-of-breed. I absolutely promise that you will not be dissapointed.
Steve
thats awesome, i absolutely love the look of the new hd's with the towing mirrors, and that gray metallic looks awesome, dogzapper... im going in today to test drive one and see how much they'll give me for my yukon, its only got about 16,000 miles, i might even wait a little to see if the 8.1 goes up in value.
bfs: what dealer did you get yours at?, i am going to courtesy chevrolet but i see that lot of hte inland empire dealers have ALOT of stock
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
