PVC Valve
Where on the 6.0l engine is the PVC valve. I can usually find them, but having trouble this time . Thanks
Top, rear of left valve cover.
DEWFPO
Can you tell me how to reset the air filter indicator ?
Press the top button on the indicator to reset it.
DEWFPO
DEWFPO
it won't reset or it shows clear with a short length of red - I failed to remember what it looked like before I changed it (I removed the filter held it up to a light to see how much light would pass thru it). I have tried pressing on it but it shows no change or movement after 3,000 miles.
what color should show if it were clogged or what should it look like after the filter is changed (clear ?)
It called a PCV valve. PVC is what you use to lay down sprinklers :cheers: Its located behind the drivers side valve cover near the firewall.
    2022LtTbZ71
    2022LtTbZ71
  • Who's Online   2 Members, 0 Anonymous, 984 Guests (See full list)
