LarryE - Please read this post
Larry,
I took some pics of the cover for the Silverado. You can see them at http://www.picturetrail.com/nh_mark
The only thing wrong with it is the hole where the antenna goes through is a little larger than it should be. I was going to sew it to make it smaller but I never got around to it. You can see this in the pics.
Like I said in a previous post. I want $50.00 plus shipping.
Let me know if your interested and send me an e-mail at [email protected] and we can talk about it.
Mark
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
