What to do
I want to clean my truck up this weekend. What is some good wax to use for like a dark copper metallic color? I bout some turtle wax car wash stuff and I'll try that first.
I like the Meguires. Works very well. If the paint is really dirty,or you havn't waxed in a while, there is also a wax cleaner and a clay. But only if want to dedicate an entire weekend.
Bill
Just don't use Gold class, it makes your paint look like it is infested with swirl marks untill you can soak it and dry it well, or use a lot of detialing spray to smooth out the wax. I only use it on my dad's car, its white. the BEST Cleaner Wax in the world, I believe it is agreed, is Zymol. "Cleaner Wax" consist of basically wax, polish and "defect"(oxidation, swirl,s light scratches) removers.  If you want a wax that will go on easy, come off easier, in a short amount of time, and make a difference in the process, I don't think you can beat Zymol Claner Wax, about 12-13 bucks a 16 oz bottle. should last you around 4 waxes or more.
Most people at this site Consider Zanio the best wax, but I've enver used it. Get a list of the first time procedures, and you'll understand why I don't want to mess with it.
But then again if you want to devote a wallet load of cash and plenty of time, go with some Zymol Councours Wax. I believe it was used on some of the ACTUAL Councours de' Elegance or something like that(the highest, most exotic car show of them all, in Europe)winning cars. But as I said prices are through the roof. They have about 4 different kinds, each kind devoted to different colors. If you don't have4 a vehilce that is exotic, or worth more than, 100,000, I wouldn't spend the money.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
