1999 Suburban how are they?
since the dealership/salesman were idiots I walked out on getting a danali, though thats the car the wife really wants. she loved the look of it.
I myself was looking at said danali and suburbans
couple other dealerships in area *ones I have got cars from* have
a danali and some 1999 Suburbans
tried to do some research on the 99 suburbans and all i can find were people complaing about replacing break pads every year.
just curious on why that is such a problem? or they just replacing them with 10dollar ones from autozone and thats why they dont last.
and any other tidbits of info would be helpful..
still debating and searching.
thanks in advance
here is current suburban i was going to look at today. yes i see the dent on the passenger side but gotta see how the body material is to see if i can fix it myself.
http://www.doranautocenter.com/index.cfm?f...9D6&StartRow=3&
Brakes will always be a problem on large vehicles, Dodge is having their share of problems on their Rams. As for the Suburuban, if it is the Older body style, you can't go wrong, they are bulletproof, well almost. If they came out with the NBS in 99, must like they did for the Silverado I STRONGLY advise you to not buy a Suburban unless it is a 2002+ I have had my share of problems with my 99 NBS Silverado and I have learned the lesson to NEVER EVER EVER! buy a new model within 2 years of it being released. :cheers:
I own a 99 Suburban SLT fully loaded and so far I had the usual problems with it. The truck has over 150K miles I bought it used 3-1/2 years ago and I love it still as much as when I first got it. So Far I replaced the brakes in front twice, water pump, fuel filter, fuel pump twice. The fuel pump is a problem on a lot of GM's trucks but the second pump I put in is a high output version which solved a lot of issues. The brakes are weak in the front like everyone says but with S/S brake lines and ceramic pads they are much better and last a long time. Unless you pull heavy loads with no brakes on a trailer then yes they will wear out fast. The intake manifold gasket is also a problem on the 5.7 Vortec's which tends to crack. The gasket is chaep to buy but it's lots of labor to replace. The 4L60E tranny is fragile but if you don't push it too much it will last. The shocks are next to replace for me but since they are the originals I would think that's normal. I hope this helps out.
Cheers
John
I have a 99 GMC Sub SLT, and I have replaced both front brake calipers, hoses, rotors, and pads. I have only had it for 8 months. I have to replace the front driver hub bearing. Something to watch for is the doors. Drive it down a bumpy road and see if the doors sound like they are going to fall off. Mine are loose and I can not figure out how to fix it. Its been a good truck for the family, so far.
And I have 74,000 miles
The hinge pins and bushings are most likely worn out on your doors.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
