Transmission trouble?
Hi,
I recently noticed a sound coming from (I think) my transmission.
It only happens once and a while but I was wondering if I should do something now before something major happens.
The sound is between a clank/or running over a aluminum soda can.
It happens when I go from Park to Drive or from Reverse to Drive.
The sound only happens right after I shift into Drive.
btw, I always fully stop when I go from Reverse to Drive.
Any ideas?
Hi,
Any ideas?
Mine does it to occasionly from reverse to drive. I think its normal. Its probably just some play in the u-joints
Probably the usual clang of splines where the driveshaft meets the back of the transmission. Everybody on this forum has experienced it with their trucks. You can take the driveshaft off, put some GM Spline Grease in the yoke (expensive stuff), and put the shaft back in. Or, you can do what me and probably 3/4 of the owners on this board have done, just ignore it. I don't think it can hurt anything. Even if the spline gets silenced, there is still at lease one U joint and the whole rear end to make noise when the direction/load on the driveshaft changes. Just normal truck sounds if you ask me.
Thanks for the reply guys,
Now that you mentioned it, a mechanic said one of my U-joints were a bit worn (this was almost a year ago).
Just glad it's not my tranny :cheers:
I you have a worn ujoint and fix it it might go away. They are cheap to fix
driveshaft lash... some backlash in diff plus some backlash in driveshaft equals a possibility of clang or clunk when you shift from one direction to another.
even a motor mount will do it.
The only really good way to find out is to have someone help you, lay down so you can see everything, have them set the e-brake and stand on the brake (best you can do for safety) and go from drive to reverse and back, over and over until you can see what's moving.
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
