trouble codes
formerlylifted
can anyone tell me how to retrieve the transmission trouble codes on a 94 gmc with a 4l60 e tranny? will the regular obd-1 retrieval with a jumper wire work for the tranny or is there a different way? :cheers:
I believe they will spit out the same way jumping A-B of aldl,
they are 2 digit Ithink 6x series
what problems are you having?
I have no reverse and only 1st gear forward-no shifts.
Forget about looking for codes.  There is nothing electrical that will cause your problem.
That's exactly what I needed to know. thankyou. Could an electrical problem have led to it, or is the root cause more likely to be from internal failure only?
