Seat Covers
I've decided to keep the 03 for awhile but I think I'm gonna need to get a seat cover I've got the edge of the drivers seat worn pretty good from sliding my fatass in and out every day. Where is the best place to order a nice seat cover? I'd rather spend a few extra bucks and get a nice one then some of those you see in stores.
If your interested in Leather give Leatherseats.com a look. I bought a kit from them for my Dakota and had it installed by a local upholstery shop. The kit came out awesome, looked totally factory.
I bought custom fit camo covers from Cabela's, made by Hatchie Bottom I think. Great product, but a bit expensive -- $250 for the front seats.
I got mine from Iggee seat covers, pricey, but an EXCELLENT fit, I got the front, rear, arm rests, and head rests. Color matches excellent, the vinyl has been mistaken for leather too. 10 outta 10 in my book.
$300+/-
I used to have Wet Okola (I think that is what they were) and they fit well and looked great, but they gave off such a bad odor of neoprene that I finally took them out. I would stay away from them.
I've never ordered from these guys. However, I have looked at their covers. They look nice for the $$. Let everyone know what you decide, especially if you order here. I'm starting to get an itch for covers as well. Good luck.
vroten :ughdance:
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
