NBS door removal?
Hey all,
I need to remove the drivers door on my 99 NBS sierra to replace the darn hinge pins. I have the kit and directions, but i hung up on one thing.
Does anyone know much these doors weight? and any suggestions on removing them without the door hanger jack? Dont want to spen 300+ for a 1 time use, and none of local auto stores rents these out.
Thanks in advance!
If you have power windows, etc., probably around 120 lbs. Instead of using a special door alignment fixture, you could get buy with a pair of cheap $ 10 hydraulic jacks, some plywoold, pieces of 2x4's and a little bit of ingenuity.
