Daytimerunning Lights
Arg
I have noticed that almost 3 in 4 chevrolet Sub, Tahoes, trucks have one of there daytime running lights out. Start looking and see if you notice the same. Defect?
I think that means that 3 in 4 people don't fix them when they burn out.
It probably depends on where you live.
They're probably the same people who don't remove the remnants of paper from their window, ever, after they once had a temporary plate.
Shouldn't be the case on the newer trucks (2004+?)..... they went to 14V bulbs for the DRL's instead of 12V and no more pre-mature burnouts.
DEWFPO
