L460-E, is it in the tahoe z71 too?
I have a dealer currently searching for a 2005 or 2006 used Z71 4x4 Tahoe and saw something about slipping tranny, but haven't found enough details to know exactly what the problem is and whether that is the same tranny in the veh i am about to buy. Should i reconsider my purchase? Pls advise. I expect to have the truck within 2 weeks.
The 4L60-E is probably the best RWD auto OD transmission. Used from the S10's to 3/4 ton trucks with little modification. All 1500 series with 4spd OD auto's are the 4L60-E or the older non electronic trans before 1991 the 4L60 ie 700-R4. So the only trans in the Tahoes are the 4L60-E. I don't like the 4L60 series because I dosen't last as long as virtually any manual trans. But, No one puts manual trans in these trucks anymore, so everyone is stuck with the 4L60-E in virtually in all trucks these days. SUV=4L60-E 2000+. still better than the others. :flag:
It is a pretty good tranny. If you tow constantly I have heard of premature failures, but since you are looking at a Tahoe, you should be just fine for a very long time with proper maintenance.
The transmission slip problem is more than likely a firmware software upgrade. It's not a fault of the actual transmission itself. I have this problem with my 05 Avalanche, but, it only happens once every 6 months or so. It's just a matter of going in to get it upgraded, which I'll do during an oil change at some point. Don't make the transmission the deciding factor for an 05, unless you're getting a Diesel. ;)
-t
As *if* the upgrade actually fixes the problem... If GM is mystified about the cause of the problem, how can they fix it?
With a redesign, you can't help but wonder why they didn't put the 4L80E in or a totally new redesign tranny if you are designing a truck from a clean sheet of paper. The 4L60E has upshift clunk problems of which there are no known fixes because of the the way the band and clutches interact. Major design flaw there.
Never had any major problems with my 2000 Silverado's transmission. Had it for 6 years and put 65,000 miles on it in that time. The reason I say I never had any "major" problems is because I did have an issue from time to time where I would be sitting at a redlight and I would take off and the tranny would act like it was in Neutral. Never took into the dealer for it though. It probably did that 5 times or so. Other than that it was bulletproof. I drove the heck out of that truck, so I was very pleased with it.
I have not experienced this problem on my 06 so far. Of course, I only have 500 miles on it right now...lol.
They don't put the 4l80 into light duties because of cost. They want to leave it has more of an incentive for people to buy medium duty trucks instead. I think they fear it would cut into those sales.
For 6L trucks and HO 6's in 1/2 tons they have the 4l70 which is a redesigned 4l60e to take more punishment. They are only offered in vortecMax's, and SS etc.
Hmm. Not sure how the 4L60 got the bad rap. I got over 200k on mine. Not a lot of towing or what not but still..
Maybe the 5.3s are harder on them?
Well, more horsepower and torque would make it harder on it I guess, but I dont think that its enough to make it fail prematurely. Despite what people say the 4L60 is a great transmission IMO.
I have 127K kms (79K miles) on my truck. It spent it's first 2 years towing a 30ft travel trailer.
So far, no issues with the tranmission at all.
the 4l60-E is a great tranny with most engines BUT as it has been mentioned before, the 5.3L is just BARELY within the 4l60-E's specs.
according to the GM Media site, the capcity of the 4l60-E is 350 lb/ft of torque, just barely above the 5.3's rated 335 lb/ft of tourque so even modest power adders can cause problems
I've seen 700R4s fail after 90k miles, and I've seen them last 180k miles. I currently have one in my '95 that as far as I know has never been rebuilt, and I'm pushing 200k on the clock. My parents towed a 35' travel trailer with their '90 suburban and it ripped the trans out after 90k miles (pretty good for hauling an 8k lb trailer). Had it rebuilt by a guy who does race transmissions, and that trans held up until my sister decided to abuse it and ate the clutches and basically the entire inside of the trans after 180k miles.
    • Pryme ! I was thinking of adding one to my 2024 6.6 gas  . Could you elaborate a bit more on your statement  Thank You
    • What a wonderful result! Great story telling to. You are quite multifaceted sir.  I'd keep it. Four is my limit too and yet we have five as well. One assigned the 'salt car' to do all those tasks you hate to ask of your 'Save for Good" crowd. 😉    Don't forget the antifreeze.    The Iron 4.3 is a favorite of mine.
    • Thanks Buck Wallace ! The more owners that tell me they are getting the same noise the more comfortable I will be with it !
    • Ancillary parts to the lower intake and connections went together without issue.   There was a brief pause when I leak-tested the fuel lines and injection system. Fuel was spraying all over. Lovely. O-rings weren't sealing the fuel lines to the spider, and inbound line was leaking at schrader valve, leaks at both flange nuts. It's moments like those when you just want to set fire to the whole shop, and be done with it. I was mostly enjoying the project up until that point, and was tracking to an agenda of having a running Blazer and a cold beverage in hand by dinnertime.    I found some larger Viton o-rings for my spider and some grease to get them to seat. One leak solved. Swapped fuel line Schrader core for old core. Still leaked. Swapped entire valve for old valve. Leak solved. Nudged the flange nuts a little tighter on the connections. Another leak solved. I could cycle the key / prime the pump and the intake was staying dry.    Reassembled the upper intake, with 10,000 vacuum lines, and filled the cooling system with water* (this is temporary, I'm not done with the cooling system yet).   Showtime!!   Cranked it over and smoke billowed, it was running rough. CEL illuminated and began flashing. P0300 and I somehow tripped a code for the TPS sensor, voltage low.    There's nothing as unrewarding as a vehicle that won't run (and produces the same code/problem) after hours of research and work.   Clearly I was in over my head. Was the timing off, did I stab the distributor incorrectly? Is the new distributor bad? With my limited OBD 1.5 data stream I really don't have a lot of parameters to see. The engine was pulling mad timing again (flooding?).   Think, Atlas, think.   1-6-5-4-3-2. One, six, five.....four, three, ....two. Wait a second. That makes no sense. 1 is the forward cylinder on the driver's side, so 2 should be the forward cylinder on the passenger side, not 6.    I can't believe it, but I'm looking right at it. Swapped 2 and 6 on the distributor and turned the key over, and...   It fired, coughed and stumbled, smoked, and then settled into a smooth idle. The scanner showed no codes, no lights on the dash, and the throttle was nice and responsive to gentle revs while it warmed up.   It's working!!! IT'S WORKING!!!   I paused for a late dinner, no cold beverage yet. I was determined to do my shakedown run. Did a basic safety and fluids check one more time and then went out and put almost 70 miles on it last night. She's a runner, runs good.   Came home and did a post-trip, post-mortem. The underside is dry *except* for where the last owner RTV'd the snow out of the intersection of the timing cover and oil pan. He said he had replaced the timing cover seal, but, my dude had clearly done it incorrectly and then tried to hold back fate with black RTV. Never works.   Yesterday morning I replaced the broken driver's door mirror. As much as I hate cheap Chinese parts, thank goodness for cheap Chinese parts. I think an entire new power mirror assembly cost me like $30, and it works perfectly. Replacement tail lights (faded, and one was busted) ran me about $12/side. I have a door pin kit ready to go in because the driver's door sags just a little and I want to fix that because there's nothing sadder than a saggy door.   I don't know what's next for this rig. Half of me wants to take some nice photos (there's a park nearby with a HUGE American Flag that always seems to be catching wind) and throw it up on CL/Marketplace for a couple grand and see if it flies. The other half of me... I've got a sweet running S10 Blazer that's been keeping my mind off of whatever I'm going through right now, and it's bringing some joy, and is cheaper than therapy. Maybe I'll keep it around for a little while. However, this is my 5th vehicle, just for me. 4 is really my limit, but they are not junk, so need very little attention. I don't know...there's a point where it's just too much and I don't see owning this truck long term. But I solved its major problem, got it running, so I'm going to stick a feather in my cap for now.   Sometimes we just need to get our hands dirty and fix something in the physical world to gain some satisfaction.
    • Happy 4th of July! Be safe out there tonight
