Got extra cash?
99silveradoz71
I was browsing around for old vehicles as I think it'd be fun somewhere down the line to own a vehicle made in my birth year. As I got to 1 site, they had a listing of various years and being a fan of the old full-size blazers, I clicked on this link and here we go. Just a bit out of my price range, ha.
88 K5 Blazer
and a Super Big Gulp cup holder, actually it should now come with 8 of them at that price
my how time makes some addon really silly looking now, like the chrome bumper guards and aluminum 'diamond' plate running boards. Other than that, it is a very nice looking rig better if it were around $20K-25K though.
hahaha 50 grand?!?! That guy is out of his mind. Straight up.
hmm....car of my birthyear eh. Well sports cars were basically in the crappy the year of mine (1984). Hmm....I'll go with Ferrari GTO. 1984 was first year. Kinda hard to argue with Twin Turbo V8.
Now Wingnut, if you could only have one, the Gremlin-X 401 or the LS2 Trailblazer SS?
But this is America d%&$-it, so you can have both......
Can I have a Gremlin with an LS2?
That would rock.
