Thieves Sorry just venting
Ok So I go to the pool hall with some friends had a couple of drinks and an hour later. I came out to find out that my truck got broken into. They pry the door near the key hole with something. So now I got a door that looks all jacked up and my steering column is all screwed up. d**n thieves have nothing to do better on a sunday and it all happen in broad daylight. On a good note they didnt take anything. Now I got to deal with the insurance tomorrow. :) poor truck.
my sympathys...good luck dealing with the insurance company! Thats always a real joy! Heck...there just as bad as the crooks that broke into your truck...they just make a living breaking into your wallet. :)
To me they wanted the truck as a whole because my Alpine radio was still in tack they ransack my glove compartment. Lucky they didnt look under the back seat to find my craftsmans tool and my bag with all my trailer hitch and watnot. And when I called to make a report they didn't send an officer. I had to make a report over the phone. I was talking to a friend and I was like what could u possible want out of a stock truck maybe for parts who knows I wish I caught them I think I would've been the one going to jail.
oh yea..I used to work at a place by a mall that cars were constantly getting broken into. Me and a buddy that I worked with had identical 94' Silverado's (his was blue though) and his was broken into 3 times and then finally stolen the 4th. Mine was broken into once. Stole my entire center piece (stereo and AC vents). Guess they didn't wanna waste any time disconnecting wires, because they just yanked it all out.
I always said that if I lost my mind I would get an AR-15 or something and sit 50 yards out and just watch that lot. Be priceless to see the look on one of their faces as their buddy gets dropped from far out.
grr...brings back memories. I found my truck broken into after I'd stayed a little late to help out the overnight crew. Never again though... :)
I used to cut sheet metal and sharpen it and mount it in key locations under the dash. Came out several mornings to find blood on the carpet.
A good kill switch is worth its weight in gold, is easy to install, and if done well will never be found. And for those of ou who think you who think your vehicle is too ugly to bother, many theives think that you are already inclined to that attitude and will steel your rig anyway becasue it is easy.
Hope you don't get in a accident with all those daggers sticking out. :devil:
I have seriously considered the sheet metal trick because damned if they are gonna get my laptop again.
The sheet metal was all under the dash to protect the stereo. I also managed to take the round key lock from a hood pin kit and machine it into the ignition lock cylinder. The net result was not having a slot to thread a dent puller into. The non-tilt Mopar columns were better than the GM columns in the 70's because there was less in there to tamper with (the ignition switch and wheel lock were well protected and activated directly off the end of the lock cylinder). I also used hidden switches to divert the power used for the starter to the horn so that when the key was turned to start the horn would blast. I figured that once or twice and a thief would probably leave rather than keep attracting attention to himself.
Sorry about your break in, that is a very common method of entry to many vehicles these days. Jimmi Jammer is a metal plate that mounts between your door skin and the lock mechanism.
I am a Jimmi Jammer dealer, checkout our website - http://www.TruckTechinques.com :devil:
    needafix
    needafix
  • Who's Online   5 Members, 0 Anonymous, 590 Guests (See full list)
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
