All Season Tire Choice For Tahoe
Good Morning,
Sorry if this is the 1,000,000th thire thread...guess I still can't find what i am looing for.
Currently I have a set of Goodyear (Wrangler) AT/S 265/70R/17 tires on my 2004 Z71 Tahoe. They aren’t bad tires, but they are getting to be a little worn. I am thinking about getting a good set of All-Season tires that I will use 80% of the time on normal roads, 10% snow, and 10% off-road. A rigid ride is 100% fine by me. I prefer that to a boaty ride. So, I assume that something with a stiffer sidewall would be the right choice.
So, what tire should I be looking at? I am a little confused with all the choices.
Regards,
John
Michelin LTX M/S
I agree. By far the best overall A/S tire. You will pay a little more up front, but you will get the payback on wear. People get 60-70K miles out of them all of the time.
I like the BFG Long Trail T/A, and my BFG A/T's.
IMO the LTX M/S tread is a bit whimpy especially on a Z71 Tahoe. I doubt the off-road traction would ge very good.
Michelin's are a bit on the pricey side, but I had the LTX A/T's and I was very happy with them. The LTX A/T has a moderately agressive tread, but isn't overboard. The road noise wasn't bad, they wore nice, and the handling was excellent both on-road and off in snow and mud.
I may get the LTX M/S for the wife's balzer as that almost never goes off-road.
Chris
I'll second the Michelin LTX M/S. I'm on my third set of LT265/75R16 LRD. I got 75K out of the first set and 70K out of the second and 10K so far on the third. Much better handling especially cornering. Super quiet highway ride. Excellent wet and dry traction. Good in light to moderate snow and so-so in mud. Yes, they are a little expensive to start but if I'm getting close to 80K out of them, it is cheaper than putting on tires that last 45-50K IMO.
Goodyear Wrangler Silent Armor will be what I'll have mounted once the OEM Wrangler ST's wear out. With just under 27k on them it looks like I'll get at least another 25k though.
Chris
The LTX A/T is an awesome tire but it is not available in a 17" tire.
I got 82,000 out of my last set of LTX A/T's on my pickup.
I agree on the Z71 Tahoe that the LTX M/S is a little wimpy looking and the stock Goodyear ATS looks good and perform fairly well ( I got 55K on my first set on wife's Z71 Tahoe). For the price the ATS is fine for this truck. You can get set of 4 for about $630 compared to LTX M/S around here for about $780.
My 2 cents......
My dad had Michelin LTX on his HD and loved them. Im thinking about them for my GMC Z71. How are you guys getting 60+ out of tires. My dad drives like an old guy and was thrilled with getting 20K out of them before they needed replaced?
I'll vote with putting on another set of Goodyear Wrangler AT/S's :smash:
I love mine and I always get around 50,000 miles on a set.
That sounds... very unusual? Shoot, my goodyear stockers (WORST WET TRACTION EVER) are about to hit 50k, getting real close to dead, though.
My dad has LTX M/S on his Acura MDX with about 18k on them, and they still look great.
Tom,You must have the ol' Wrangler ST's,The worst tire Goodyear ever come out with,I can't believe GM even puts those things on a 2wd truck let alone a 4x4! :cool:
To get 50k out of them is pretty darn good though,but like you said...NO WET TRACTION :smash:
I have them balanced and rotated every 10,000miles. I am also anal about maintenance and have a lifetime alignment that gets checked every 6 months. As long as nothing is worn or out of alignment, LTX's should last at least 70K IMO.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
