New pics!!
Sweet Truck!
Thats the kind of truck i dream of having one day!!! I really like the clear corners and the euro tails as well... They add a nice look to a bad @ss truck!
Paco, grill and bumper covers are painted, soon to come are Escalade handles and a C3 tailgait handle also painted. Thanks for the compliment.
Now why in the heck does GM not paint those bumper caps the same color as the rest of the truck.  They look so much better that way, unless the truck has black flares and accesories on it.
8100HD nice looking truck!!!
got a extended cab 2500 w/8.1/allison with the standard rims looking to go both taller and wider after I burn up the stock tires so:
what size wheels and tires are u running there? how much were those wheels? and did u lift your torsion bars? it seams to sit higher in the front than mine (may be crew ext. cab diffrence?)
Raventia, Tires are 285 BF AT's on American Racing Baja's 16x8, My torsion bars are cranked up a bit.  When I bought the rims they were on special for $82 each tires about $150 each. Hope this helps. :D
Quote from 8100HD, posted on Oct. 23 2001,08:22
Raventai, Tires are 285 BF AT's on American Racing Baja's 16x8, My torsion bars are cranked up a bit.  When I bought the rims they were on special for $82 each tires about $150 each. Hope this helps. :D
shure dose, are they 285/75R16 right or is the sidewall higher? no clearance problems in turning I hope, and the setback is good right?
reason I am asking is because those are the kind of wheel style I was looking at and that is a great price the stock wheels/tires leave the wheel well verry emty looking and a bit more height would be nice to  :thumbs: did u get the rims locally or on line? seams the high shipping weight/cost would negate any saving u could get on line?
these are the ones here?
You will need to trim your lower airdam, and maybe your inner left fender liner, not a big deal, mine rub alittle on my mudflaps but that's all, well worth the looks it gets.
The truck is looking good, painting all those pieces really makes a big difference
BTW you may want to check the link in your sig, it's got an extra URL tag at the end of it, just a heads up.
  • 5 months later...
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
