alternator
I just replaced my altenator, I was losing power while running headlight or heat in the morning .amp guage would drop to 10 amps causing to stall at red lights.I still have the problem only stalls in gear though ,and has poor acceleration and it skips.HELP!!!
  • 4 weeks later...
Check all battery connections, could be a poor ground.
Sounds like a poor ground or corroded cable. Look closely at the ends of the cables between the insulation and the connection. If there is a break in the insulation and you see corrosion, REPLACE the Cable. If you're comfortable with a VOM check for resistance in the cables. Anything over a few oHms and the cable is on it's way out. Also clean all the ground straps, and attaching points to clean metal, Wire brush all bolts, screws to clean metal, and use either die-electric grease or Vaseline on all contact points.
Check your voltage at the battery with the engine OFF, then check it again with the engine ON. Off should be between 12.6 and 13.5 or so. Running should be Above 13.5 and no more than 15.0. (Do this BEFORE and AFTER cleaning all the cable ends, write down the results and see how much difference). Make sure you also clean the Starter Terminals. Also make sure there is at least one ground strap or even two (much better) (in addition to the Negative battery cable on the engine) to the frame, preferably one next to the starter on the block, and the other on the other side of the block.
If the cables are corroded, get the LARGEST Diameter cable you can get (usually 2 gauge). I use 0 gauge welding Cable and solder my connections on the ends, coat the ends with liquid tape, then shrink wrap them. You wouldn't believe how fast my starter turns now and how cool (temp wise ) the cables are when I'm drawing 80-90 amps thru them. Just route them same as factory, and if they are within 3" of the exhaust manifolds, use header heat wrap.
Larry
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
