Seat Covers...
I bought Hatchie Bottom camo seat covers from Cabela's and am very happy with them. When I bought mine, only cloth was offered, for about $250. Now you can also opt for neoprene.
I bought a set of truck seat covers from Auto Zone for my truck to use temporarily until I find something better. However, they fit an d look so good that I have kept them. The cost is only about $ 50/pair, and they have a zipper on the side and openings for seat mounted seat belts, which these trucks have..
You know what, I think I'm going to do the same thing... I see so many "custom" ones for $129... but I have to wonder if they are worth it when I see other custom ones for double that... You're saying Autozone has ones with the should seatbelt and are nice fit. I have the custom cloth interior... how about the center console and seat? I'm trying to deal with a shedding dog, and I don't want it to turn into a crap-box just yet!
Thanks,
Pete
I have the same interior and I keep the center console down, so essentially I have two bucket seats. I do not have any cover on the center seat/console. My seats are grey color and the seat cover I got are pretty nice color match too.
I just installed seat covers from Cover Craft. I have the crew cab with the front split bench and the rear 60/40 folding rear bench. They fit great. I got the front and rear covers for about $250 total. I got them from Auto Parts Warehouse.
I ended up with the Cover King (?) Cordura ones.. $114 delivered and they cover the 40-20-40, including the armrest, headrests, etc.
Should be great with the dog!
  • 1 year later...
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 511 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
