installing wait4me tune
The first time....took me 30 minutes. Neighbor came over to see what I was doing now to my truck.
The second time (I swapped the original back in before going to the dealerhsip).....less than 5 minutes.
can anyone give feed back on the wait for me tune? what to expect? can you really get a program for both 87 and 93 octane? how does the computer know the difference? do you feel any performance gains in an all stock 5.3? what about gas mileage?
I have had Jesse's tune in my GMC since August 2005. I love it, especially for the price, it can't be beat.
Don't expect much of a MPG improvement, I'm lucky if I saw a 1 MPG gain.
I had him do the 87 octane tune and a few other things. I was told I'd see a 2-3 MPG improvement, but no deal.
Great deal though :crackup:
How much power you think you got? More than 10-15hp?
No idea.
Are the relearn directions included?
As I understand it, you need a Tech II device to do the relearn.
It is only $45.00 (.5 hours labor) at your local GM dealership :crackup:
yes but if you do this at the dealer they will then know you are running a aftermarket program. then you wont be able to switch back to stock to bring in for service.
Most dealers don't care about things like that. If that is a concern, you can go to any local reputable garage and have it done there, cost should be about the same.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
