And Now 600 -
patrick
Seemed like we were all waiting to hit 500 members and now we're at 599! Sometime on 9/5, GMTC should have 600+ registered members.  This site has doubled in numbers this summer.  Any bettors on what it will be by the end of the year?  freak2.gif
Congrats to Mervz, Josh and all of the moderators and characters here that make this such a great site to visit everyday.
I noticed the 599 last night then forgot about it. Wow, we should have a mutual pat on the back for this mile stone. People join because of mutual interest and that we all have something to offer. thinkerg.gif Good job!!!
(Edited by LT at 3:03 pm on Sep. 5, 2001)
If I remember right, BigPerm is Ryanbabs brother.  I think thats why we havent seen him....he was kinda messing with us.  Gotta love those brothers right Ryan?
