a/c pulley cracked
gruzovik
My a/c pulley cracked and is making this annoying/loud ticking noise.I tried removing it but couldnt,in my haynes manual there is only explanation on how to remove a/c compressor,nothing about the pulley.Does anyone know how to remove this pulley,or is it removable at all?another question i have(if i cant fix a/c pulley,or not going to replace the compressor)how to bypass the compressor,should i just get a drivebelt for same year/model but the one that goes for a no a/c model and just bypass the a/c compressor?thanx in advance
p.s.btw it is a 93 gmc sierra with a v6
you can replace the pully with a new one with out replaceing the compressor
You will need this tool to remove it (ac compressor clutch/hub,pully puller)
And this tool to reinstall it
You should be able to go to autozone and rent the tools.
Far as parts you should get the coil and clutch also when replaceing the pully, most likely they got damaged with the pully
Or you can get the pully and bracket that mounts were the compressor is if you dont want to fix the compressor
If you have any questions let me know
