1/2 to 1 ton Pickup truck conversion
I was given a 1979 Chevy Scottsdale 1/2 ton 4X4 by a Family member, and cosmetically the truck was an eyesore...but it runs!!
The truck has a SBC an "LS9" to be exact, a 4 speed muncie and NP205 Transfer case.
So being I'm always looking to improve things, I was able to find a 14 Bolt 10 1/2" ring
gear rear end, and a Dana 44 with 8 lug Hubs cheap ( $500.00 for both..in reasonable
condition)
I have found that in making the swap I also got new "U" Bolts for the rear axle, and a
new "U" bolt spring plate..I'm now doing shopping for the best price for a new
Driveshaft to fit the "!350" "U" joint used by the GM 14 bolt and to keep things simple
and not to spend more money swapping out the Transfer case yoke, I'm going to keep
the existing "U" bolt size .
What I have found baffling is that when I went to buy a new "WARN" locking hub for the
front axle ( which is supposed to be a 3/4 Ton) WARN actually calls it a 1 Ton axle,
and the same problem occured when I went to go to a local wrecking yard to get a replacement hub........I told them it was a 3/4 ton...but they disagreed showing me
hubs that look like my 1/2 ton hub.....
The Hub in Question is about 4 1/2 inches in diameter...and the "WARN" locking
mechanism mounts on a sast extension, instead of directly on the hub itself...
I would welcome any comments on this 3/4..or 1 ton hub..
Richard.....Reno, Nevada
Retired US Navy
  • 6 months later...
got any pictures, i have seen this only one other time. we have an old 1973 farm truck that has a dana 44 8 bolt with the larger 1ton hubs. i have just recently swapped out my dana 44 3/4ton with a dana 60 1ton on my 79 chevy, on the 3/4 ton dana the hubs were only 3.5 inches in dia. your best bet may be to find a set of oem spicer lock out hub from a junk yard. they are better quality anyway, i had warn hubs on both the 3/4 and 1ton axles and destroyed the splines on both. never had any trouble with the spicer hubs yet.
condition)
Retired US Navy
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
