rear end "wiggle"?
Norsemanu
Hi all,
I'm new here, just found the site and looks like it will be extremely helpful for me as I go through this 1995 GMC Safari van I have. I'm doing something very unique to it (I'll try and fill ya' all in on that later) and will be driving it a fairly long distance for the first time. Problem is, I've had this strange problem when I make a slow, sharp turn... only way I can describe it is it feels like the whole rear of the van just sort of wiggles slightly. Can a u-joint going bad have this effect? Of maybe there something going on with the differential? Any advice would be much appreciated.
A couple of suggestions:
Limited slip might be ratcheting if you have it - perhaps a gear oil change might help with that
or
Low tire pressure on one side.
or
Bad Tire - slipped belt, could try rotating the front's to the back and see if it makes a difference.
Sounds like it'll be a little trial and error troubleshooting it.
