Soft Tonneau Covers
Looking to put a soft tonneau cover on my truck to cover stuff up when the weather is bad. I want a soft one so that it is easy to remove and put away when not needed. my dad has a hard one on his truck and its a pain in the a$$ to put on and take off. which brand is better: Lund, Truxedo, Extang.......?
Would you guys recommend a tri-fold, roll up, snap on, velcro, or the seal and peal type?
Also are these something that will attach if i have the bed rail covers on my tuck?
thanks
I have an access cover on mine and it's awesome. It has the velcro strips, a must for closure in cold weather, and the rails are on the inside edge of the bed rails.
I've had Extangs on the last two trucks and have had nothing but great results. One the first one, I had one corner piece fail and contacted Extang and they promptly sent out a completely new hardware kit including all four corner pieces. One of their new models has the lift function that allows easy access to items that are close to the cab.
I've had two ACCESS roll-up covers, they are the best in my opinion. They also come with a lifetime warranty on the velcro. If it wears out they will send you new velcro strips and they are held in by one small rivet on each side!
I`ve got the Lund Genesis Trifold onmy `05. It is great. I can take it off in 1 minute, as it is held on by 4 clamps. I can fold it up, and snap it together, and have bed access. I have no complaints. I have gone to Home depot before, and people ask, " where ya gonna put all that plywood?" I simply fold it up in a minute, and lay the wood in. HA! It gets em every time.
i have heard that the soft covers are not completely weather proof. is that true or is there one that is better than another for that?
I have the Truxedo Truxport, Velco sides, 4 clamps, rolls up, Its great! Plus I like it better than Lunds (which I have had before) because it doesn't give that "covered wagon" look.
I've got the Truxedo Lo-Pro.  Awesome cover...I had an extang on my previous truck and it was a pain in the butt to snap in cold weather.  The Truxedo kicks butt!
That is a great cover. I was looking at that one when I bought my Extang.
A buddy on another forum offered my sabre new/shipped for $100 so I jumped on it :chevy:
