Hard Start when Warm
HI all,
This one has me stumped. I ran a search without luck. It takes 2 or 3 tries to get the truck to start when its warm. Cranks and cranks and then finaly catches and runs bad for a minute or two, then its fine. Cold start has no issues. I changed the plugs and check Fuel pressure. Anyone had this problem? BTW I have a 2000 1500 with the 5.3.
Most likely it is going to be your fuel pressure regulator. If you take the hose off at the regulator and gas pours out your regulator is bad. I had the same problem a couple months ago and after the fix I haven't had a problem since.
  • 3 months later...
  • 10 months later...
I had a GMC Safari that did the same thing. It was a little electric black box that cost about $15. I am having the same issue with my GMC Sierra. I don't remember the electronic part. It cost me $50 to have it anaylized in "95". I'm sure it would be more than that now. If you get an answer let me know.
HI all,
I had a similar problem with my wife's Explorer. It was an injector leaking down. The leaky injector effectively flooded the engine which made for a difficult hot restart. But there was no problem when the engine was cold as the fuel presumably had evaporated out of the manifold by then.
You could try doing a pressure leak down check to see if it is within spec but you may have to plug the FPR return to isolate that as a leakdown source.
Good luck.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
