High Idle Code 35
CRATE 572
When the engine is cold I have to press the gas slightly
or it won't start and keep on the gas for about 10 secs
or it will stall. After that it will idle at 1000 and when warmed
up it sets code 35 IACV error. The pintle on the valve was
staying seated in the throttle body at start up and when hot.
I also found a leak at the base gasket. I had a complete
TBI unit off of a good running parts truck and installed
it and a new gasket. It made no change, the truck runs the
same and I checked for vaccum leaks at the gasket, manifold,
and hoses. I'm sorry about the length of this post but I could
really use some help.
