Senior Moderator of the Year 2001
Frank S
:(  :D  :D  :D  :D  :D  :D  :D  :thumbs:  :D  :thumbs:  :D  :thumbs:  :D  :thumbs:  :D  :thumbs:
As you all are aware, GMTC has a monthly award for "Senior Moderator of the Month" and then an annual winner who is voted for out of the 12 monthly winners.
2001 monthly winners are as follows:
Jan - Frank
Feb - F. Sheridan
Mar - yZR2k
Apr - Frank Sheridan, "yZR2k"
May - Frank S.
Jun - yZR2k Sheridan
Jul - Frank yZR2k Sheridan
Aug - "FS" (Winner requested to remain anonymmous)
Sep - yZR2k Sheridan
Oct - F.S. yZR2k
Nov - Frank Sheridan
Dec - Frank S. yZR2k
                                NOW THE ANNUAL AWARD ANNOUNCEMENT
Well, YOUR VOTES ARE IN AND FINALIZED! Even the hanging shads were counted. The annual winner?
               SENIOR MODERATOR OF THE YEAR 2001 - yZR2k, Frank Sheridan
CONGRATULATIONS FRANK! It was close but you DA MAN!  Many thanks to all of the runners up.
:thumbs:  :D  :thumbs:  :D  :thumbs:  :D  :thumbs:  :D  :thumbs:  :D  :thumbs:  :D  :thumbs:  :D  :thumbs:  :D  :thumbs:
No way in the world am I giving you a decal now Newbie.
Besides,Zane and Josh have them all.
WAH? I just nominated and elected you Senior Moderator fo the Year and this is how you treat me?
Kiss ass never gets you anywhere.....
Well Hal,let's break this down:
I am the only Senior Moderator so that means I'm up for several awards,regardless of how dubious they may be such as:
Worst Senior Moderator,Best Dressed,Worst Dressed,Most Eligible,Most Undesirable,Senior Moderator you'd least like YOUR daughter to date,and one more just for Digs,Senior Moderator with the saggiest pants.
I'm pretty sure I'm forgetting a few so fell free to add to the list [leaving self wide open for what's to come]
Sure it does.  I got to be a moderator, right? :(
Frank- I'm starting to think he might want more than just a $5 decal.  Certainly he could afford $5 or $6 bucks, so what is it that Newbie really wants from you?  Hmmmmmm........ :lookaround:
I dunno.
It's king of scary if you think about it.I already told him that Josh and Zane have the decals so that can't be it.
Hmmmm..............
I don't even want to know.
The fact that you are the ONLY Senior Moderator and that there was absolutely no other competition is irrelevant Frank.  You won fair and square.  Unanimous vote if I remember right.  Enjoy your year.
Everyone said you look real cute with the diamond tierra although I havent seen it myself.  Please post some pix.
    CaptainDad
    CaptainDad
  • Who's Online   7 Members, 0 Anonymous, 566 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
