A/C trouble with 1996 Silverado
pmrpete
My brother in law is having trouble with his A/C on his 1996 Silverado 4x4. It will not blow cold air. He recharged it but that didn't work. Also, truck was in an accident and the dash popped out, had to be re-connected. A/C never worked since. Could ther be a short somewhere as a result of dash popping out? Blows but no cold. Where is a good place to start looking?
Any help would be appreciated!
First thing to do is to check if the compressor is engaging. If it is not the next thing to check is the cycling switch on the accumulator. You can jumper across the terminals but be careful not to spread them so as not to make good contact.
Thanks for the reply. How do I check to see if the compressor is engaging? I don't have much experience with a/c units. :driving:
When checking for A/C issues, you have to check both the electrical portion of the system and the integrity of the refridgerant part also.
It could be a leak, but not likely if just the dash popped out, because the heater box is mounted seperately from the dash assm (Ya gotta remove the dash to get to the evaporator). So its probably the switch. Either it got disconnected, a short in the system, the pressure switch is bad, or the compressor clutch/field is bad also.
Do as what was stated above and jump the pressure switch. If the compressor comes on, then you have a leak. If not, then you are going to have to check to see if the compressor is getting power to it.
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
